I followed exactly the instructions in:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.Aspx?ArticleID=6158
and now my web.config looks like this:
<configuration><configSections><section name="infragistics.web" type="System.Configuration.SingleTagSectionHandler,System, Version=8.3.20083.1009, Culture=Neutral, PublicKeyToken=7DD5C3163F2CD0CB"/></configSections>
</configuration>
and I'm getting an error:
"Could not load file or assembly 'System, Version=8.3.20083.1009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified."
in the Scripts folder I have only one java script ig_WebGrid.js that I updated (Since I get the following error: http://community.infragistics.com/forums/p/18367/66833.aspx)
And another question :
which files should be in the scripts folder in addition to the files I have updated?
Please help
Maya
i think you should check out a book called java complete reference.
i used it for my exams and project,
Web Development
The ig_shared must come before the webdatagrid file to initialize ig_cscom
<script type="text/javascript" language="javascript" src="ig_Shared.js"></script>
<script type="text/javascript" language="javascript" src="ig_WebDataGrid.js"></script>
Vince McDonald"] Maya, This different message means that your web.config changes have taken effect. It sounds like the file ig_shared.js is missing from the directory where you've deployed your scripts. I recommend copying all of the JavaScript files used by any of our ASP.NET controls in NetAdvantage for .NET over to your scripts directory.
Maya,
Hi Vince,
I am getting a similar error to Maya.
I have an aspx page with the WebDataGrid loading data (works great). I then wanted to detect when the selection of a row changes (I am able to fire javascript perfectly). I did some more research and I found out about some of the Infragistics javascript functions like igtbl_getGridById (yes I am new). I kept on getting issues when calling igtbl_getGridById before finding out that I needed to include js files. I found ig_WebGrid.js and added the reference to this script file from my aspx page.
I now get the following error that Maya gets when the webpage first loads:
Error: 'ig_csom' is undefined
Comment: If I choose not to debug, I can continue on as normal however when I select a row, I only ever get a null value and I assume that this error has something to do with my problems.
I did some more research and ended up adding all the js files to my same script folder (including the ig_shared.js that is mentioned in your response). I then added the references to the script files:
<script type="text/javascript" language="javascript" src="js/ig_WebGrid.js"></script><script type="text/javascript" language="javascript" src="js/ig_Shared.js"></script>
I am still getting the same error. Do I need to reference every single ig_WebGrid*.js file? If so, I tried that as well and I had no luck. I also used this link for my reference, but still nothing (http://help.infragistics.com/Help/NetAdvantage/ASPNET/2009.2/CLR3.5/html/Web_Deployment_Overview.html).
Any idea what I am doing wrong?
Thanks in advance for any help you can provide me.
Thanks a lot, now its working!!!
I just had to add the js files for all of the infragistics controls that I have added to me webSite.
