Hi - I have a popup panel on my page that contains a number of webdropdown controls.The web drops downs are in a cascading style...so the drop down above affects the available data in the web drowndown below.I am using the dropdownobject.loadItems() method from the client side code.if I change drop down 'A' and that in turn calls the loadItems() method of drop down B, then immediately click a button in my popup panel that causes the panel to close/hide itself, then I get an error in the javascript when the loaditems has completed as the drop down 'B' is no longer visible...but it is trying to switch focus to that control (which the loaditems() method seems to do automatically?!).The line it fails on is: this._elements["Input"].focus(); within the function :- // handles async AJAX response _responseComplete: function(callbackObject, responseObject)I made this easy to demonstrate by adding in a 5 second delay in the server side code of the ItemsRequested event, so I could easily change drop down A, then click a button on my panel which hides the panel (and all the drop downs!)...then a few seconds later the server side code completes and the java code falls over!Is there a way I can determine on the client side if dropdown is in the middle of an ajax request? I have tried looking through the online docs but couldn't really spot anything obvious!many thanks in advance!Jonathan
Hi Jonathan,
This issue is already reported internally, the issue number is # 22775. It will be available in the next service release.
Angel
Great news Angel...do you have a rough idea of when the next release will be? I know you have the new release for WinForms already...so I hope that means the WebForms release is going to be soon?!
cheers
Jonathan
Yep, the WebClient 9.2 will be released very soon. I can let you know additionally, once it ships officially.
actually - thinking about this I would still like to know clientside when the loadItems() method has finished getting the data - as I may want to display a 'busy' gif and/or disable my 'save' button while it is busy.
is there a 'load complete' type client side event?
Yep, you can use the "ItemsRequested" client-side event. When you invoke loadItems(), response comes back and everything gets initialized in the dropdown on the client, the event will fire. Alternatively, you can use the "Initialize" client-side event itself, but it will fire in much more cases compared to "ItemsRequested".
Hope it helps,
You're a star Angel! That works perfectly ;)
