435
MultiDimensionalArray binding
I am working with a multidimensional array and am wanting to see if i can bind it to the webdatagrid.
Essentially, my Data looks like this..
RowName.ColumnName.SubName.Value
I want the grid to look like the following
RowName        ColumnName1    ColumnName2
                           Sub 1      Sub2        Sub1      Sub2
SomeRow       Val1         Val2          Val3       Val4
SomeRow2     Val1         Val2          Val3       Val4
This can have many more rows and many more columns than above.
The Sub1 and Sub2 are the Sub keys of each column with the values being stored in the array.
Is this possible?  Do i need to do some kind of banding?
I can get a dataset with tables that list all possible rows, columns and subrows if needed and output the aggregate data as:
RowName    ColName     Sub1    Sub2
SomeRow     Col1             Val1      Val2
SomeRow     Col2             Val3      Val4
And so on.
  • 14049
    I am not quite clear on what the requirement is, can you give an example of the data source in C# and draw a picture of the desired rendering? Thanks.
