Hello folks,
I need to get the WebHtmEditor worked for other language that are not in the built in (arabic, chinese, korean and portuguese).
I have been looking in the documentation page about multilanguage support for the WebHtmlEditor and I've found this lines.
"the default text of all labels, ToolTips, menus, dialog boxes and drop-down list can be translated to a number of languages. It is easy to customize your own language files, because the language files are plain XML text files "
The thing is that I can´t open the .dict files with any editor, it seems I need a special editor in order to customize my new languages.
Can anybody give me some help about it?
It's OK I've found the solution my self.
I have to create a custom language file and then set the CustomLanguageFile property.
The built int language files are in C:\Program Files\Infragistics\NetAdvantage for .NET 2008 Vol. 2 CLR 2.0\ASP.NET\Scripts
Thank you
