Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
We have uploaded our site using Infragistics asp.net 8.2 components.
Our webserver is shared-hosted. (godaddy)
Our site is in the root folder. Dll files are in bin directory
Ig_common folder contains 20082CLR20 and images folder of Infragistics components.
But still we receive following error.
What can be the cause of it ? Is it related to Infragistics or the web site hosting itself ?
Please help us to solve this issue. Thank you in advance.
Assembly section Web.config is also added below.
Comment
Error Occured..
Message :
Required permissions cannot be acquired.
Source:
Mscorlib
Form:
QueryString:
ReturnUrl=%2findex.aspx
TargetSite:
System.Security.PermissionSet ResolvePolicy(System.Security.Policy.Evidence, System.Security.PermissionSet, System.Security.PermissionSet, System.Security.PermissionSet, System.Security.PermissionSet ByRef, Boolean)
StackTrace:
at System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Boolean checkExecutionPermission) at System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Int32& securitySpecialFlags, Boolean checkExecutionPermission)
From web.config:
<compilation debug="true">
<assemblies>
<add assembly="Infragistics2.WebUI.WebCombo.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.UltraWebGrid.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.Shared.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="Infragistics2.Web.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.UltraWebCalcManager.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.UltraWebGrid.ExcelExport.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.UltraWebListbar.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.WebDataInput.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.WebDateChooser.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.WebHtmlEditor.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.WebSpellChecker.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.Misc.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.WebNavBar.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.UltraWebToolbar.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.Excel.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.UltraWebChart.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="System.Configuration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
<add assembly="System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
<add assembly="System.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
<add assembly="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.Web.Services, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.DirectoryServices, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.DirectoryServices.Protocols, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.EnterpriseServices, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.ServiceProcess, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.Web.RegularExpressions, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="Infragistics2.Documents.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.Shared.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.UltraWebGauge.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.UltraWebGrid.DocumentExport.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.UltraWebNavigator.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.UltraWebTab.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.WebResizingExtender.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.WebSchedule.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics2.WebUI.WebScheduleDataProvider.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
</assemblies>
I found the answer here: http://forums.infragistics.com/forums/p/11159/82156.aspx#82156
Infragistics has separate copies of the dll's--one set does not allow partially trusted callers, and the other set (the one I needed) does allow partially trusted callers.
Please use the assemblies that are marked with APTCA (Allow Partially Trusted Callers) when hosting in such an enviroment. You can find all the APTCA assemblies if you used the default install locations here:
For CLR 2.0:
C:\Program Files\Infragistics\NetAdvantage 2009.2\ASP.NET\CLR2.0\APTCA
For CLR 3.5:
C:\Program Files\Infragistics\NetAdvantage 2009.2\ASP.NET\CLR3.5\APTCA
My situation is similar. We are using Infragistics 9.2 with our application hosted on GoDaddy.
I have set up a sample application that works fine until I add an Infragistics control (I've used Infragistics grid, combobox, and menu, all with the same effect).
Anyone know a workaround for this? Here is the error we get:
Description: The application attempted to perform an operation not allowed by the security policy. To grant this application the required permission please contact your system administrator or change the application's trust level in the configuration file. Exception Details: System.Security.SecurityException: That assembly does not allow partially trusted callers.Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
[SecurityException: That assembly does not allow partially trusted callers.] ASP.psiclients_aspx.__BuildControlmnuAddEditDelete() +0 ASP.psiclients_aspx.__BuildControltcAddEditDelete() +85 ASP.psiclients_aspx.__BuildControl__control5(TableCellCollection __ctrl) +37 ASP.psiclients_aspx.__BuildControltrInstructions() +82 ASP.psiclients_aspx.__BuildControltblInstructions() +237 ASP.psiclients_aspx.__BuildControlfrmClients() +94 ASP.psiclients_aspx.__BuildControlTree(psiclients_aspx __ctrl) +106 ASP.psiclients_aspx.FrameworkInitialize() +46 System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +56 System.Web.UI.Page.ProcessRequest() +80 System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context) +21 System.Web.UI.Page.ProcessRequest(HttpContext context) +49 ASP.psiclients_aspx.ProcessRequest(HttpContext context) +4 System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +181 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
