1004
Line Chart Legend Probrem
I have a problem with Legend in LineChart (Rf: Picture). I add some Series with Color but the correspondant Color in Legend are different. I try using FillSceneGraph and ChartDrawItem like in some example here in Forum but i didnt work:
        static void UltraChart_ChartDrawItem(object sender, ChartDrawItemEventArgs e)
            if (e.Primitive is Polyline || (e.Primitive is Box && e.Primitive.Path != null && e.Primitive.Path.IndexOf("Legend") != -1))
                if (e.Primitive.Series != null)
                    if (e.Primitive.Series.Label == "Sparkasse i.Zshg.m. Produkt-, Unternehmensmeldungen")
                        e.Primitive.PE = new PaintElement(Color.Red);
                    if (e.Primitive.Series.Label == "Deutsche Bank i.Zshg.m. Produkt-, Unternehmensmeldungen")
                        e.Primitive.PE = new PaintElement(Color.Blue);
                    if (e.Primitive.Series.Label == "Dresdner Bank i.Zshg.m. Produkt-, Unternehmensmeldungen")
                        e.Primitive.PE = new PaintElement(Color.Green);
                    if (e.Primitive.Series.Label == "Postbank i.Zshg.m. Produkt-, Unternehmensmeldungen")
                        e.Primitive.PE = new PaintElement(Color.YellowGreen);
                    if (e.Primitive.Series.Label == "Commerzbank i.Zshg.m. Produkt-, Unternehmensmeldungen")
                        e.Primitive.PE = new PaintElement(Color.Yellow);
Any Solutions are welcome.
  • 28496
    Suggested Answer
    probably e.Primitive.Series is going to be null there.
    try this instead:
      private void ultraChart1_FillSceneGraph(object sender, FillSceneGraphEventArgs e)
                for (int current = 0; current < e.SceneGraph.Count; current++)
                    Primitive currentPrim = e.SceneGraph[current];
                    bool legendBox = currentPrim is Box && currentPrim.Path != null && currentPrim.Path.Contains("Legend") && currentPrim.Row == 0;
                    if (legendBox && current < e.SceneGraph.Count - 1)
                        Text nextLabel = e.SceneGraph[current + 1] as Text;
                        if (nextLabel != null)
    string nextLabelText = nextLabel.GetTextString();
    // do what you want here based on the text in the legend label
