I have a simple pie chart (see code below) with two data columns column1=79.48 and column2=20.52, however, when the chart is rendered, it only displays a single slice of 100.00%. I am using a datatable with two fields. Am I just not referencing or assigning something properly?
<igchart:UltraChart ID="igPieChart" runat="server" BackgroundImageFileName="" BorderColor="Black"BorderWidth="1px" ChartType="PieChart3D" EmptyChartText="Data Not Available. Please call UltraChart.Data.DataBind() after setting valid Data.DataSource"Section508Compliant="True" Style="position: relative"Version="8.1"><PieChart3D BreakAllSlices="True" BreakOthersSlice="True"><ChartText><igchartprop:ChartTextAppearance ChartTextFont="Arial, 7pt" Column="-2" ItemFormatString="<DATA_VALUE:00.00>"Row="-2"></igchartprop:ChartTextAppearance></ChartText></PieChart3D><ColorModel AlphaLevel="255" ColorBegin="Pink" ColorEnd="DarkRed" ModelStyle="CustomLinear"></ColorModel><Effects><Effects><igchartprop:GradientEffect></igchartprop:GradientEffect></Effects></Effects><Axis><Z LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="False"><MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1"Visible="False" /><MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1"Visible="True" /><Labels Font="Verdana, 7pt" FontColor="DimGray" HorizontalAlign="Far" ItemFormatString=""Orientation="Horizontal" VerticalAlign="Center" Visible="False"><Layout Behavior="Auto"></Layout><SeriesLabels Font="Verdana, 7pt" FontColor="DimGray" HorizontalAlign="Far" Orientation="Horizontal"VerticalAlign="Center"><Layout Behavior="Auto"></Layout></SeriesLabels></Labels></Z><Y2 LineThickness="1" TickmarkInterval="10" TickmarkStyle="Smart" Visible="False"><MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1"Visible="False" /><MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1"Visible="True" /><Labels Font="Verdana, 7pt" FontColor="Gray" HorizontalAlign="Near" ItemFormatString=""Orientation="Horizontal" VerticalAlign="Center" Visible="False"><Layout Behavior="Auto"></Layout><SeriesLabels Font="Verdana, 7pt" FontColor="Gray" FormatString="" HorizontalAlign="Near"Orientation="Horizontal" VerticalAlign="Center"><Layout Behavior="Auto"></Layout></SeriesLabels></Labels></Y2><X LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="False"><MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1"Visible="False" /><MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1"Visible="True" /><Labels Font="Verdana, 7pt" FontColor="DimGray" HorizontalAlign="Near" ItemFormatString="<ITEM_LABEL>"Orientation="Horizontal" VerticalAlign="Center"><Layout Behavior="Auto"></Layout><SeriesLabels Font="Verdana, 7pt" FontColor="DimGray" FormatString="" HorizontalAlign="Near"Orientation="Horizontal" VerticalAlign="Center"><Layout Behavior="Auto"></Layout></SeriesLabels></Labels></X><Y LineThickness="1" TickmarkInterval="10" TickmarkStyle="Smart" Visible="False"><MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1"Visible="False" /><MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1"Visible="True" /><Labels Font="Verdana, 7pt" FontColor="DimGray" HorizontalAlign="Far" ItemFormatString="<DATA_VALUE:00.##>"Orientation="Horizontal" VerticalAlign="Center"><Layout Behavior="Auto"></Layout><SeriesLabels Font="Verdana, 7pt" FontColor="DimGray" FormatString="" HorizontalAlign="Far"Orientation="Horizontal" VerticalAlign="Center"><Layout Behavior="Auto"></Layout></SeriesLabels></Labels></Y><X2 LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="False"><MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1"Visible="False" /><MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1"Visible="True" /><Labels Font="Verdana, 7pt" FontColor="Gray" HorizontalAlign="Far" ItemFormatString=""Orientation="Horizontal" VerticalAlign="Center" Visible="False"><Layout Behavior="Auto"></Layout><SeriesLabels Font="Verdana, 7pt" FontColor="Gray" FormatString="" HorizontalAlign="Far"Orientation="Horizontal" VerticalAlign="Center"><Layout Behavior="Auto"></Layout></SeriesLabels></Labels></X2><PE ElementType="None" Fill="Cornsilk" /><Z2 LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="False"><MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1"Visible="False" /><MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1"Visible="True" /><Labels Font="Verdana, 7pt" FontColor="Gray" HorizontalAlign="Near" ItemFormatString=""Orientation="Horizontal" VerticalAlign="Center" Visible="False"><Layout Behavior="Auto"></Layout><SeriesLabels Font="Verdana, 7pt" FontColor="Gray" HorizontalAlign="Near" Orientation="Horizontal"VerticalAlign="Center"><Layout Behavior="Auto"></Layout></SeriesLabels></Labels></Z2></Axis><Legend Location="Bottom"></Legend><Data ZeroAligned="True"></Data></igchart:UltraChart>
That was it. I knew I had to be overlooking something simple, I just couldn't see it. I've not done alot of charting. Thanks for the great response & for responding so quickly.
try toggling the value of the igPieChart.Data.SwapRowsAndColumns. set it to "True." the default setting is "False," and by default it expects a table with one column and multiple rows.
