660
WebDropDown does not drop when in WebDialogWindow started hidden
Straight up simple WebDropDown located in a DialogWindow works when when DialogWindow started normal but not when started hidden,  There are some other goofy effects on the dialog window but I have found work arounds for all but this.  ASP.NET DropDownLists work fine but trying to use the IG controls.  Please help!
Simplified section of the page that demonstrates this issue: (what's up with your forum that it spaces out paste for Visual Studio ??)
<ig:WebDialogWindow runat="server" ID="WebDialogWindow2" Modal="true" InitialLocation
="Centered"
WindowState
="Hidden">
<Header CaptionText
="Options 23">
</Header
<ContentPane
<Template
<div
<table
<tr
<td
Output Format
<br
<ig:WebDropDown runat="server" ID="WebDropDown12" Width="200px" DropDownContainerWidth
="200px"
DropDownContainerMaxHeight="200px" Height
="131px">
<Items
<ig:DropDownItem Text="PDF Document" Value="PDF" Selected="True"
<ig:DropDownItem Text="Web Page" Value="HTML"
<ig:DropDownItem Text="Word Document" Value="RTF"
<ig:DropDownItem Text="Excel Spreadsheet" Value="Excel"
<ig:DropDownItem Text="Excel (no headers)" Value="ExcelDetailsOnly"
<ig:DropDownItem Text="Fax Document (tif file)" Value="TIF"
<ig:DropDownItem Text="Notepad (txt file)" Value="Text"
<ig:DropDownItem Text="Raw Data (csv file)" Value="CSV"
</Items
<Button ImageUrl="add_up.gif"
</ig:WebDropDown
</td
</tr
</table
</div
</Template
</ContentPane
  • 660
    Verified Answer
    Yes, it was the Z-order issue and you can see with the right background.
    EnableDropDownAsChild=false and adding <ClientEvents Initialize="initDropDown" /> to the control and then
    adding the following to the script
     function initDropDown(sender,args)
            sender.behavior.set_zIndex(200000);
    resolved the issue.  Thanks
  • 24671
    Verified Answer
    You can have a look at the following thread:
    http://forums.infragistics.com/forums/p/23845/88164.aspx
    To sum up - the issue is that WebDialogWindow puts a very big zIndex so that it always appears on top, therefore in order for the dropdown container to appear on top of the dialog window, its z-index must be higher.
    Hope it helps,
    Angel
