How do correct the following?
Get "Could not find schema information for the element 'infragistics.web'. " after running "Application Styling Configuration 9.2". Have looked at the Web.config and moved <section name="infragistics.web -- etc. " to the top of "<configSections>" and still get the messages .
Also get same messages for:
Could not find schema information for the attribute 'enableAppStyling'.
Could not find schema information for the attribute 'styleSetName'.
Could not find schema information for the attribute 'styleSetPath'.
Thanks!!!!
I'm facing the same issue: no schema information. The Infragistics.Web reference: if you mean the "normal" referecing method by using "Add reference", I cannot find Infragistics.Web, I can find Infragostics4.Web instead but if I do this , it does not solve the issue.
Here the current extract of my web.config:
configSections>
section name="infragistics.web" type="System.Configuration.SingleTagSectionHandler,System, Version=1.0.3300.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
<infragistics.web styleSetName="Default" styleSetPath="~/ig_res"/>
system.web>
compilation debug="true" targetFramework="4.0">
assemblies>
add assembly="System.Web.Abstractions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
add assembly="System.Web.Routing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
add assembly="System.Web.Mvc, Version=2.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
add assembly="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
add assembly="WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
add assembly="System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
add assembly="System.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
add assembly="Infragistics4.Web.v10.3, Version=10.3.20103.2013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
add assembly="Infragistics4.WebUI.UltraWebNavigator.v10.3, Version=10.3.20103.2013, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
add assembly="Infragistics4.WebUI.Shared.v10.3, Version=10.3.20103.2013, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
add assembly="Infragistics4.WebUI.Misc.v10.3, Version=10.3.20103.2013, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
add assembly="Infragistics4.WebUI.WebHtmlEditor.v10.3, Version=10.3.20103.2013, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
add assembly="System.DirectoryServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
compilation>
So, where is the isse? How can I get the correct reference to the schema?
YoursStephan
You should add a reference to Infragistics.Web in yout project.
Hollisj,
I would not hold my breath on trying to find a solution to the error message you are getting. I gave up waiting, gave up so much I did not renew my contract with Infragistics.
BUT, how I worked around the problem is just close web.config and the error did not show up or cause a problem. I know this is not a good answer, but it has not caused me any problems.
Keith
I am having the same issue. I am used to using older version...way older version and now trying to convert old sites to VS2010 and latest Infragistics tool set.
Anyone have a resolution for this?
Mony,
Did yo ever get a solution to the above problem??
Thanks Keith!
