20
Excel Export : System.OutOfMemoryException
Hi
Urgent help would be appreciated.
I am using Infragistics.excel to export the data to Excel 2003. While exporting 85000 records from a
 datatable I am getting following exception:
Exception of type 'System.OutOfMemoryException' was thrown at Infragistics.Excel.WorkbookFontData.Clone() at
 Infragistics.Excel.GenericCacheElement.FindExistingOrAddToCache[T](T newElement, GenericCachedCollection`1 collection)
at Infragistics.Excel.GenericCacheElementProxy`1.SetCollection(GenericCachedCollection`1 rootCollection)
at Infragistics.Excel.WorksheetCellFormatData.OnRemovedFromRootCollection()
at Infragistics.Excel.GenericCachedCollection`1.Remove(T element)
at Infragistics.Excel.GenericCacheElement.Release[T](T element, GenericCachedCollection`1 collection)
 at Infragistics.Excel.GenericCacheElementProxy`1.BeforeSet()
at Infragistics.Excel.WorksheetCellFormatProxy.set_Alignment(HorizontalCellAlignment value)
at Humana.Medicare.Mamba.Utility.ExportToExcel.FillExcelRowsData(DataTable sourceDataTable,
Workbook& excelWorkbook, Worksheet& excelWorksheet, Boolean isHorizontalDirection)
at Humana.Medicare.Mamba.Utility.ExportToExcel.GenerateExcelFile(String fileName, DataSet sourceDataSet)
at Humana.Medicare.Mamba.Web.ImportExport.Pages.ExportMAData.ExportButton_Click(Object sender, EventArgs e)
at System.Web.UI.WebControls.Button.OnClick(EventArgs e)
 at System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument)
at System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument)
at System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument)
 at System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
  • 44743
    Try upgrading to the latest SR for the version you are using. There have been a few memory improvements to support large amounts of data. If you still have the problem, I would need to see a sample to try to reproduce the issue. With the current information, I'm not sure what the problem is.
