115
How to Fix Column by default
Is there any possible way to fix (ColumnFixing) WebDataGrid Column by default?
  • 33839
    Verified Answer
    Hi Salis,
    There is no way to fix a column from the aspx page as there is to filter a column currently.  You can do this in code inside of the page load function like so:
    this.WebDataGrid1.Behaviors.ColumnFixing.FixedColumns.Add().  The add function has 5 overloads.  It can take a FixedColumnInfo object, or a Column key (string) or Column object, each with optional FixLocation enum.
    Hopefully, this will get you started.
    regards,
    David Young
