145
Referencing a cell value in Workbook1 in another cell in Workbook 2.
I have the following requirement:
" write value to an Excel file (file 1) which is an input to a calculation in another file (file 2) whose result is linked back into the first file (file 1), recalculate both files, and read the result of the calculation back from file 1".
Basically I want to link 2 workbooks where the 2nd workbook has cells that references cell values from the 1st workbook.
I read at http://forums.infragistics.com/forums/t/34190.aspx that this feature is not supported. If not supported, can you confirm if you plan to have this in one of your future releases.
Yamini
  • 44743
    Currently, using external values for calculating formula values at run time is not supported. However, you can create formulas which reference external cells and then export them to the file correctly. It sounds like you are looking for the latter. Is this correct?
