I have a page with a WebHierarchicalDataGrid displaying 2 band levels. The page may receive a querystring parameter which identify a row (primary key) on the first band to be expanded. How can I make the row expand on page load ? Should this be done In server code or javascript ? Please help.
Thanks.
Perfect, thanks a lot!
Hey,
I'm not sure whether you mean to expand a root row or a row in level one, but that shouldn't matter too much, unless you are also using LoadOnDemand, which would make it hard on the client. To expand a row on the client, try the following.
function init(grid, args) { var grid = $find("WebHierarchicalDataGrid1"); grid.get_gridView().get_rows().get_row(1).set_expanded(true); }
<ClientEvents Initialize="init" />
If you would rather do it on the server, I did it in the WebHierarchicalDataGrid's DataBound event.
protected void WebHierarchicalDataGrid1_DataBound(object sender, EventArgs e) { this.WebHierarchicalDataGrid1.GridView.Rows[1].Expanded = true; }
Let us know if you need more help.
regards,David Young
