Dear All,
Iam using infragistics version 9, in asp.net application how to enable and disable the following controls using java script,
WebTextEdit, WebDateChooser, DropDownList, CheckBoxList, RadioButtonList.
Please suggest a answer.
Thanks in advance,
Vasanth.
Hello Vasanth,
Please disable the WebDateChooser using the below lines of code.
var isDisabled = false;
function WebDateChooser1_TextChanged(oDateChooser, newText, oEvent){ //Add code to handle your event here. oDateChooser.setEnabled(isDisabled);}
I will go ahead and reply the same to your case.
Asma Developer Support EngineerInfragisticswww.infragistics.com/support
I can you help you with Infragistics contols WebTextEdit and WebDateChooser.
You can enable or disable WebTextEdit by using below lines of code.
var isEnabled = true;var isDisabled = false;function WebTextEdit1_TextChanged(oEdit, newText, oEvent){ //Add code to handle your event here. oEdit.setEnabled(isDisabled);}
The WebDateChooser is not behaving as I am expecting, so I have to investigate it further. So I will go ahead and create a case for you and send an Initial Update on the case.
Sincerely,Asma Developer Support EngineerInfragisticswww.infragistics.com/support
