Hi Everyone,
I am looking to build a functionality of multi-select checkbox with "All" option. Selecting "All" should select all the available options in the WebDropDown and unselecting it should de-select all the options.
Is this a default feature of WebDropDown or do I have to write some code to achieve this functionality?
I will appreciate any help or ideas from the community!!
This functionality is not supported out of the box, but it can be achieved by adding a "special" item to the dropdown that has the text "Select All", then enable multiple selection in the following way: EnableMultipleSelection=True, MultipleSelectionType=Checkbox.
After that you can handle the SelectionChaning/SelectionChanged events, and in the client side traverse all items and select them:
for (var i=0; i< dropDown.getLength(); i++)
var item = dropDown.get_items().getItem(i);
item.select();
Hope it helps. Let me or the Development Support group know if you have any further questions.
Angel
