745
Select Index Event Problems of WebDropdown
HI,
thnx for your reply for the prvious post,  i had one more query. The thing i am selecting mutiple items in a drop down, and i need to take all the selected items and need to pass it to a query.. but after selecting the one time the postback is not happening..i'll send my code to you,please go through that and send me reply
.aspx
<ig:WebDropDown ID="DD_PropZone" runat="server" EnableDropDownAsChild="false" EnablePaging="false"
width
="150px"
EnableMultipleSelection="true" MultipleSelectionType="Checkbox" EnableClosingDropDownOnSelect="false" DropDownContainerHeight="150px" Font-Names="Arial" Font-Size="8pt" DropDownAnimationType="EaseOut" OnSelectionChanged="DD_PropZone_SelectionChanged" AutoPostBack="True" CssClass
=".igdd_ListItem"><ClientEvents Initialize="initDropDown" />
.cs page
<AutoPostBackFlags SelectionChanged="On" /></ig:WebDropDown
protected
void DD_PropZone_SelectionChanged(object sender, Infragistics.Web.UI.ListControls.DropDownSelectionChangedEventArgs
e)
string m=""
for (int
i = 0; i < DD_PropZone.SelectedItems.Count; i++)
if
(i == 0)
m =
"'" + DD_PropZone.SelectedItems[i].Value.ToString() + "'"
else
m +=
",'" + DD_PropZone.SelectedItems[i].Value.ToString() + "'"
if (DD_PropZone.SelectedValue != "Select"
sSqlQuery =
"SELECT DISTINCT City_Locality FROM [City_State_Country_LookUp] WHERE (City_Locality IS NOT NULL OR City_Locality !='') AND City_Zone IN(" + m + ") ORDER BY City_Locality ASC"
SqlDataAdapter sda91 = new SqlDataAdapter
(sSqlQuery, Conn);
DataSet ds91 = new DataSet
sda91.Fill(ds91);
dd_Locality.Items.Clear();
dd_Locality.DataSource = ds91.Tables[0];
dd_Locality.DataValueField =
"City_Locality"
dd_Locality.DataTextField =
"City_Locality"
dd_Locality.DataBind();
dd_Locality.Items.Insert(0,
"Select"
else
BindPageLocality();
ModalPopupEx_AdSearch.Show();
 and after selecting any item...its taking lot of time...and aftr am not able to select next item...
plzz reply me quickly
  • 24671
    Suggested Answer
    I am not sure if i understand the issue correctly, but - it sounds more like a performance issue to me. I suggest to remove the AutoPostBack=True setting, then use AutoPostBackFlag for SelectionChanged=On, and keep AutoFiltering=Server or AutoFiltering=Off. This, combined with using the latest service release for the product, should make all of the performance issues go away :)  - I hope so.
    Let me know if it helps,
    Angel
