I have a webDialogWindow that appears correctly in IE7, but fails to display in Firefox.
My application uses WDWs heavily in a settings page - and all these work fine in Firefox.
One page in my application has an asp:Panel that I add one or more UserControls to.
Each of these UserControls has a WDW (modal) defined within it (initial WindowState is hidden)
When the user clicks on a control in the UserControl, I
- page:postback - add the UserControls back into the asp:Panel
- UserControl postback: draw data-driven charts
- UserControl on_Click handler - draw dialog contents, set windowState to Normal
Behavior:
- in Firefox, the entire page gets a gray overlay (modal dialog behavior)
- no dialog! (When I use Firebug it "Breaks on Error" - elem is undefined)
- stack shows:
browserHandler() : line 2948
(?) () : line 47
_resize() : line 502
onResize() : line 492
I'm running the latest service release of NetAdvantage 20092 (2056)
Any clues?
This is a major issue I'm trying to resolve - let me know if i should submit a ticket.
Mike- Thank you so much for suck a quick response! I'm going to upgrade to 2009.2, I have 2009.1 and just hadn't done the upgrade to this app yet since I didn't know there was this issue.
Hopefully this resolves the issue, if not guess I'll be submitting a ticket.
Jenn
I updated to the latest IG release (2009.2 SR 2056)
But it was still happening intermittently on my development machine...
So, I uninstalled ALL previous versions of NetAdvantage, installed only 2009.2, then the Service Release... and viola', my javascript crash in Firefox went away...
maybe the old versions were confusing ASP.net? I honestly didn't go back and try to find root cause :)
Mike
I'm having the same issue with IE6 browser. It works fine on IE8 but not IE6 with sounds like same behavior as FireFox for you.
Did you get resolution to this?
Jennifer
