Hello.
I was wondering what is the web equivelant to the winforms UltraDataSource.
Is it the WebHierarchicalDataSource? And if yes, how can I manually add the bands, childbands etc to this?
Here is the code I'm using to my winforms application:
UltraDataSource datasource = new UltraDataSource(); datasource.Band.Columns.Add(this.X_AxisName, typeof(String)); UltraDataBand childBand = datasource.Band.ChildBands.Add("cbKey"); childBand.Columns.Add(this.Y_AxisName, typeof(String)); childBand.Columns.Add(this.DataName, typeof(Int32)); childBand.Columns.Add(TotalPercentageString, typeof(Decimal)); childBand.Columns.Add(FiltersPercentageString, typeof(Decimal)); datasource.Rows.SetCount(xaxisavailabledata.Count); #endregion #region Load data on datasource int noOfFilteredData = GetNoOfTotalFilterdData(); int noOfData = 0; decimal posostoTotal; decimal posostoFilters; for (int i = 0; i < xaxisavailabledata.Count; i++) { datasource.Rows[i][0] = GetX_AxisString(xaxisavailabledata[i]); UltraDataRowsCollection childRows = datasource.Rows[i].GetChildRows("cbKey"); childRows.SetCount(yaxisavailabledata.Count); for (int j = 0; j < yaxisavailabledata.Count; j++) { noOfData = GetNoOfData(xaxisavailabledata[i], yaxisavailabledata[j]); //if (noOfData > this.LowerDataLimit) //{ posostoTotal = 0.0M; posostoFilters = 0.0M; if (this.X_RecordsDataTable.Rows.Count > 0) { posostoTotal = (100 * (decimal)noOfData) / ((decimal)this.X_RecordsDataTable.Rows.Count); posostoTotal = decimal.Round(posostoTotal, 2); } if (noOfFilteredData > 0) { posostoFilters = (100 * (decimal)noOfData) / ((decimal)noOfFilteredData); posostoFilters = decimal.Round(posostoFilters, 2); } childRows[j][0] = GetY_AxisString(yaxisavailabledata[j]); childRows[j][1] = noOfData; childRows[j][2] = posostoTotal; childRows[j][3] = posostoFilters; //} } } #endregion return datasource;
How can I rewrite this code for my web application since there is no UltraDataSource for the asp.net?
Thanks!
WebHierarchicalDataSource is not exactly an equivalent to the WinForms UltraDataSource. It is different concept of a data source control. Its purpose is to combine flat data sources (DataViews) and then define DataRelations between them. Then it automatically generates hierarchy based on these relations. For more info you can take a look at our online samples at
http://samples.infragistics.com/2009.2/WebFeatureBrowser/Default.aspx.
For your web application you can use WebHierarchicalDataGrid to display the data. Since you generate the data manually in the code-behind there is no need to use the WebHierarchicalDataSource. You can use directly DataSets or collections of custom objects, here is an example using ArrayLists:
<ig:WebHierarchicalDataGrid ID="whdgTest" InitialDataBindDepth="1" Width="600px" runat="server"> </ig:WebHierarchicalDataGrid>
protected void Page_Load(object sender, EventArgs e) { if (!IsPostBack) { whdgTest.DataSource = GetData(); } }
private IEnumerable GetData() { ArrayList data = new ArrayList();
for (int i = 0; i < 10; i++) { ArrayList children = new ArrayList(); data.Add(new { X_AxisName = string.Format("x axis data {0}", i), Children = children });
for (int j = 0; j < 3; j++) { children.Add(new { Y_AxisName = string.Format("y axis data {0}", j) // etc. }); } }
return data; }
Anyone? I could really need a hand here to migrate my winforms code to my website...
