In RowEditingTemplate i am placing Webdropdown and give the DataSoruceID="SqlDataSoruce2"
Server Error in application,
if i remove DataSoruceID then, i am able to see with gird and RowEditingTemplate with dropdown, but there is not data in dropdown
Why should I use stand alone dropdown? any way the problem is solved in 2010 version. but the dropdowns are not opened in RowTemplate
What happens if you put a stand alone dropdown and assign the same DataSourceID?
