135
ig_common and javascript
 Im havign problems with my ig_common VD not accessing my javascript files. Im using VS 2005 and the 7.3 version on your controls. I created my VD pointing to 'C:\Inetpub\wwwroot\aspnet_client\Infragistics\' this is where my versions of the controls are and subfolders (Forms, Scripts, etc). I have added the assemblies in the web.config.
 I made a sample page by dragging the UltraWebTab to the page and put a simple label and textbox in there. All I want to do is grab the text of the textbox by using the javascript function ' igedit_getById()' but when debugging it says its not defined, so its not being found. I did no more than that, so if Im missing a step (referencing the js files in the web.config?) This is just a simple example I put together to grab the value of the label, so that I can then add it to my larger project when I get this all figured out. And the javascript function I created is inline with the page, using the ' igedit_getById()' function
Thanks.
