I have a multi-layered chart that I am attempting to turn off or hide the series labels on the X-axis of my chart (see attached image). I've been attempting to hide them by changing their color to white:
this.UltraChart4.Axis.X.Labels.SeriesLabels.Visible = false; this.UltraChart4.Axis.X.Labels.SeriesLabels.FontColor = Color.White;
So far, no luck. Any ideas on how I should go about this? I'd like to keep the vertical dates, but get rid of the horizontal series labels that are all compressed together and make no sense.
I figured out what my problem was. I had the rows and columns swapped in my dataset. I realized that I should be working w/ the Label not the Series Label. I used:
xAxisColumn.Labels.Visible = false;
And it cleaned things right up. Sorry for the confusion.
If you are using composite chart, try looking at:
http://forums.infragistics.com/forums/p/4074/20187.aspx#20187
