Hi There,
I am just learning the Aikido WebDataGrid to utilize in my project and when I was just create and run the application as same as sample installed in the local which has the URL as below
http://localhost:1026/igSamples/WebFeatureBrowser/Default.aspx where I have selected the "DataBinding - Template Columns" sample which falls under ASP.NET AJAX(Aikido) >> WebDataGrid and my application throws a compilation error stating that
"The type or namespace for name 'CustomerDataSource' could not be found (are you missing a using directive or an assembly reference?)"
and the showing at the below line of code.
CustomerDataSource dataSources = new CustomerDataSource();
Kindly anyone help me out to solve this issue?
