On refresh on the ScheduleInfo I use Infragistics.WebUI.WebSchedule.Appointment object to fill the appointments in the DayView, and for every refresh I have changes in the appointments. When these changes are in the Subject, Start or End Date, everything it's OK. But when I try to change the background-color of the appointment, it doesn't work for every appointment. Some appointments change it's background color, but some of them don't take their new color or take the color of the existing appointment.
To set color I use the following properties:
appointment.Style.BackColor
appointment.Style.ForeColor
The property Style doesn't work properly every time, I put the name of the colors in the Subject and it's displayed the right color, but it's doesn't color the background.
My second problem is with the processing image. When I Refresh or navigate SceduleInfo the processing image is displayed in the right bottom corner, but I didn't change anycode to do that. I like to be in the center like it was before.
Iva
Try to use CustomRules like this:
Protected Sub WebScheduleInfo_DataBinding(ByVal sender As Object, ByVal e As System.EventArgs) 'Handles WebScheduleInfo1.DataBinding
Dim indexTabN As String Dim infoOnTabN As WebScheduleInfo
For index As Integer = 1 To Me.UltraWebTab1.Tabs.Count
indexTabN = index.ToString infoOnTabN = CType(Me.UltraWebTab1.Tabs.GetTab(index - 1).ContentPane.FindControl("WebScheduleInfo" & indexTabN), WebScheduleInfo)
For Each appt As Appointment In WebScheduleInfo1.Appointments
Select Case appt.Importance Case Importance.High 'appt.Style.BackColor = Drawing.Color.Red ' Doesn't work appt.Style.CustomRules = "color: red;" appt.Style.CustomRules = "background-color:lightyellow;" Case Importance.Low appt.Style.CustomRules = "background-color:lightblue;" Case Importance.Normal appt.Style.CustomRules = "background-color:lightgreen;" End Select
Next Next
End Sub
