Hello I am giving ultrawebgrid's height at server side. At client side scroll-bar is set to auto.
If I have multiple records, there is scroll-bar on the grid. At that time, when I move the scrollbar to select a row of that grid, the size of the Grid is first set to some size greater than what I had set at server side and then it sets to the size specified by me in the server side code. This gives a flickering kind of effect to my rendering of Grid. This works perfectly if I select a record in a grid which doesn't have a scroll bar. I have observed that initially during rendering of the grid, the scrollbar is not placed at the exact zero position(top of the Grid) and I can use mouse to move it upwards. When I place the scrollbar at exact zero position and select a record the automatic Grid resizing doesn't happen. Here is my code for setting height at server side:UltraWebTab1.Height = Unit.Pixel(330)dgWebGrid.Height = Unit.Percentage(100)dgWebGrid.DisplayLayout.FrameStyle.Height = Unit.Pixel(250)Remember problem (flickering) occurs when the location of scroll bar is changed on the grid i.e. when I scroll to select a row and initially when the scroll-bar is not automatically placed at zero position.Whats the reason of this and what can I do to keep the Grid size static even when there is a scroll-bar and I scroll to select a record?Thanks in Advance
