185
NameValidating event for DocumentExport
I have an UltraWebGrid that I am exporting.
I set the DownloadName property but it seems to "clean up" the name, which is not what I want.
I was able to solve this problem with the excel export using the NameValidating event handler.
Does the document exporter have a similar event?
  • 4960
    Suggested Answer
    It does not, although you can suggest NameValidating be added here,
    http://devcenter.infragistics.com/Protected/RequestFeature.aspx
    To change the name used in the download, you should be able to subclass the UltraWebGridDocumentExporter class and override the protected virtual DownloadNameResolved property,
    public class YourWebGridDocumentExporter : UltraWebGridDocumentExporter
         public YourWebGridDocumentExporter( )
         protected override string DownloadNameResolved
             get
                 return   yourDownloadName  + "." + this.DownloadExtension;
    then call Export on this subclassed control.  The name returned by DownloadNameResolved will be used to construct the HTTP response.  Same caveats apply as if you were using the NameValidating event.
