Is there any sample code that shows a drop down box being used in a WebHierarchicalDataGrid?
I get my code to work until I put the dropdown in the form. Then when I attempt to update I get the message:
Failed to load viewstate. The control tree into which viewstate is being loaded must match the control tree that was used to save viewstate during the previous request. For example, when adding controls dynamically, the controls added during a post-back must match the type and position of the controls added during the initial request.
I follow the video sample for a WebDataGrid and that behaves just fine with the same datasource and update commands. Has anyone got this functionality to actually work? I'm at a loss and a sample markup that actually works would be a godsend.
Hi there,
Is there any solution to the above mentioned issue, I'm facing it from a long time time to find a solution.
Thanks in Advance
Abhishek
I'm having the same issue as both of you. A response about this would be helpful.
I do have a little more information as to what may be causing the problem...
My WHDG has three levels. I have a dropdownlist editor provider for the third level down. What's wierd is that everything works fine until I put a TemplateDataField in the top level. That's when I get the viewstate error.
It's too bad nobody responded. I have the same issue. Were you able to resolve it?
