475
WebGrid methods Stop working in New mozillaFirefox 3.6. URGENT HELP
Hi
  My client was using mozilla for his application, and it was upgraded to Mozilla/5.0 (Windows; U; Windows NT 6.0; en-GB; rv:1.9.2) Gecko/20100115 Firefox/3.6 (.NET CLR 3.5.30729).
  The application has two button in order to move row up and down. Everything has been working for alomost 2 years. NOw with the new version of mozilla this functionality is deleting the rows instead of moving them :( .
  In the aspx code I have this:
<div style="float: left; width: 10%; text-align: center;">
 <br/>
<div onclick="enableDisableAdvancedPanel(false);moveUp();return false;">
 <img id="imgup" src="facilityFiles/images/up.png" alt="move up" /></div>
<br/>
<div onclick="enableDisableAdvancedPanel(false);moveDown();return false;">
<img id="imgdown" src="facilityFiles/images/down.png" alt="move down" /></div>
</div>
The javascript functions specified above are defined as follow:
function enableDisableAdvancedPanel(flag)
  var advancedPanelObj = igpnl_getPanelById(getId('pnlAdvancedOptions'));
  advancedPanelObj.setEnabled(flag);
function moveUp()
 var selected = igtbl_getGridById(getId('uwgClientSelectedColumns'));
 var row = selected.getActiveRow();
 if (row != undefined)
  var rows = row.OwnerCollection;
  var index = row.getIndex();
  if (index > 0)
   rows.remove(index, false);
   rows.insert(row, index -1);
  selected.setActiveRow(row,false,false);
function moveDown()
  if (index < rows.length - 1)
   rows.insert(row, index + 1);
  As you can see, what the moveup and movedown functions are doing is deleting the row and then inserting again in another index position.
  Is the rows.inser(row, index + 1) not working anymore in the new mozilla???
  The version of infragistic is 7.3.20073.1054 . Problem with the version????
  Another thing is that I have notice the java error console of mozilla showing the following:
   Warning: Empty string passed to getElementById().
  And then an error exception as follow:
  Error: document.getBoxObjectFor is not a function
Source File: http://reports.conferencecare.com/ReportManager/WebResource.axd?d=49_cJwDJJJCynFFCK8gBVR6u37OiPfvzyWkiN4m3OsFj55_oRbU18LlJcWjjXIVnG-BauKrqR0RIFs3IHK1kKb4YJkwOD6a9_EaN23Z7NTBer5rNOZwhvkV6-4PMu1Uw0&t=633548304820000000
Line: 3237
Is the infragistic function getBoxObjectFor not compatible with the new mozilla anymore?
  When I open the url error exception, it shows me a huge javascript code (auto generated by infragistic) and exactly the position of the exception as follow (The position is in Bold font):
function igtbl_getAbsBounds(elem, g, forAbsPos)
	var r = new Object();
    if (ig_csom.IsIE && elem.getBoundingClientRect)
        var rect = elem.getBoundingClientRect();
        r.x = rect.left;
        r.y = rect.top;
        r.w = rect.right - rect.left;
        r.h = rect.bottom - rect.top;
    else if (ig_csom.IsFireFox && document.getBoxObjectFor(elem))
        var rect = document.getBoxObjectFor(elem);
        r.x = rect.x;
        r.y = rect.y;
        r.w = rect.width;
        r.h = rect.height;
	else
		return igtbl_getAbsBounds2(elem,g);
  The autogenerated javascript code is label as:
  * Infragistics WebGrid CSOM Script: ig_WebGrid.js
  * Version 7.3.20073.1054
  * Copyright(c) 2001-2006 Infragistics, Inc. All Rights Reserved.
  Can someone help, Maybe the Gurus of the infragistic webgrid components. Has someone else having expirience with the mozilla 3.6 version....... Please help
  • 49378
    Hi appliednetworksolutions,
    It has been a while since your post, in case you are still in need of assistance I am glad to offer some help.
    As I can see from the information you have given, your version of Infragistics is 7.3. Firefox 3.6 is supported since our .NetAdvantage for .NET 2010 Volume 1 release. Therefore I can suggest you to try upgrading your product version to our latest release.
    Please contact me if you ahve any questions.
    Petar Ivanov
    Developer Support Engineer
    Infragistics, Inc.
