I just migrated by code from Infragistics.V8.2 to V9.1 and already I'm getting loads of cross browser issues.
One in case is the UltraWebGrid. I've set the following
e.Layout.AllowDeleteDefault = Infragistics.WebUI.UltraWebGrid.AllowDelete.Yes;
When I run the code in IE 6, the delete works fine but if I do the same in Firefox, safari or any other browser nothing happens.
Jesbin
Hi Jesbin,
It has been a while since you opened this thread, however if you still require assistance with this matter, I would be happy to help.
Internet Explorer versions 6 and up are currently supported by our products, however older versions of the Mozilla and Safari browsers may not be supported in the newer versions of .NetAdvantage. You can find a detailed list of the supported browser versions (and the latest release of .NetAdvantage where they were supported) at:
http://ko.infragistics.com/support/supported-environments.aspx#SupportedEnvironments
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
