380
Change WebExplorerBar height client side
Hi all,
is there a way to change the height of a WebExplorerBar control client side when user is resizing the browsers window (window.onresize event)?
Here is a snipped of code i've tried (without success)
                    var explorerbar = document.getElementById('ctl00_cphRight_webRight');
                    if (explorerbar != null)
                        explorerbar .style.height = iContentHeight;
Dom
  • 3726
    Yes you can.
    First options is like you already pointed out: document.getElementById("...") will return the main control DIV html element. Then you can adjust the height by using div.style.height = "200px";
    The other option is:
    If you have explorer bar java script object instance like:
     var control = $find("WebExplorerBar1");
    if(!$util.isNullOrUndefined(control))
      control.get_element().style.height = "200px";
    where get_element() will return the main HTML element of the control. i.e. the DIV in our case.
    Hope this helps.
