50
Finding HTML Control on Page loaded into tab
I am trying to find an image button located in a page contained with in a WebTab. I want to click the button from Javascript when the user selects the tab. I have the client side event firing and can see the tab using getTabAt, but I cannot figure out how to find the image button when it located in an aspx page instead of being a control placed inside the form.
This code works when the control is located in the tab, but does not when the control is located in a page that is loaded into the tab:
       var tab = $find("<%=WebTab1.ClientID%>");
        var tabIndex = e.get_tabIndex();
        if (tabIndex == 1) {
            var imgButtonId = tab.getTabAt(tabIndex).findChild("ImageButton1").id;
            var imgButton = document.getElementById(imgButtonId);
            imgButton.click();
Any help would be appreciated.
Brent
  • 24497
    Suggested Answer
    Hi Brent,
    If you use ContentUrl, then tab uses iframe to render it. There is method/property of tab item get_iframe(). So, if ContentUrl is local, then you probably will get access to its document and can find child element from that document. Below is example (with skipped validations for nulls).
    var tabItem = tab.getTabAt(tabIndex);
    var iframe = tabItem.get_iframe();
    var doc = iframe.contentWindow.document;
    var elem = doc.getElementById('ImageButton1');
    <I think similar will be added in newer versions to implementation of findChild.>
