As far as I have been able to tell, this is not implemented, so I put together a handler that should work. This is preliminary (I have not gone all the way with implementation), but it might help others:
Normal 0 false false false EN-CA X-NONE X-NONE MicrosoftInternetExplorer4
function eventToChar(code) {
if (code < 32 || // Shift codes, etc.
(code > 32 && code < 41) || // Arrows, etc.
(code >= 45 && code <= 46) || // Ins, Del
(code >= 91 && code <= 93) || // Window keys, select key
(code >= 112 && code <= 123) || // F1 - F12
(code >= 144 && code <= 145) || // Num lock, scroll lock
code >= 256)
return null;
else
return String.fromCharCode(code);
function dropDownMatch(control, match) {
if (control.get_enableCaseSensitivity()) {
for (i = 0; i < control.get_items().getLength(); i++) {
// if (items[i].get_text() == match || items[i].get_text().startsWith(match)) {
if (control.get_items().getItem(i).get_text() == match || control.get_items().getItem(i).get_text().startsWith(match)) {
return control.get_items().getItem(i);
} else {
if (control.get_items().getItem(i).get_text() == match.toLowerCase() || control.get_items().getItem(i).get_text().toLowerCase().startsWith(match.toLowerCase())) {
function selectFirstDropDownMatch(control, match) {
var matchedItem = dropDownMatch(control, match);
if (matchedItem) {
if (!control.behavior.get_visible() && !control.behavior.get_isAnimating()) {
control.openDropDown();
control.__scrollToItem(matchedItem);
control.set_activeItem(matchedItem);
return true;
} else
return false;
function startClearMatchTimer(control) {
clearTimeout(control._clearMatchTimerID);
control._clearMatchTimerID = setTimeout(
function() { clearMatchTimer(control); }, 1500);
function clearMatchTimer(control) {
control._matchText = undefined;
function inputKeyUp(control, event) {
var code = event.get_browserEvent().keyCode;
var match = control._matchText;
if (!match)
match = "";
if (code == 8) { // Backspace
match = match.substring(0, match.length - 2);
selectFirstDropDownMatch(control, match);
control._matchText = match;
startClearMatchTimer(control);
matchChar = eventToChar(code);
if (matchChar) {
match = match + matchChar;
if (selectFirstDropDownMatch(control, match)) {
control._matchText = match; // Only set if the match succeeded
Assign it to <ClientEvents InputKeyUp="inputKeyUp" /> in the <ig:WebDropDown> to get the functionality. Uses the control's own case-sensitivity settings, and the 'search string' clears after a second and a half (the 1500) of not typing.
--=- Ritchie Annand
You might also want to assign a DropDownClosing to an event like this:
function clearMatch(control, event) { control._matchText = undefined;}
...especially if you up the amount of time the match text hangs around. This way you can hit <ENTER> on your choice and jump right back in and select something else.
