1740
Setting the input texbox of a multi-select WebDropDown with the values selected in the page_load
My WebDropDown has multi-select checkbox enabled. I have default selection initalized (more than 2 items) in the code-behind page_load event. How do I reflect the input textbox with the selected values? It shows by default only the first item which in my case is not selected.
I tried to initialize the input textbox from javascript in the onload event but I can't access the WebDropDown using $find('WebDropDown1'). This gives me null value.
Any ideas someone!
  • 12679
    Suggested Answer
    I would  suggest  something like this:
       39     void WebDropDown1_PreRender(object sender, EventArgs e)
       40     {
       41         WebDropDown1.Items[2].Selected = true;
       42         WebDropDown1.Items[3].Selected = true;
       43
       44         string currnetValue = "";
       45
       46         foreach (DropDownItem item in WebDropDown1.Items)
       47         {
       48             if (item.Selected)
       49             {
       50                 currnetValue += item.Text+",";
       51             }
       52             if (item.Selected)
       53             {
       54               WebDropDown1.CurrentValue =
       55                     currnetValue.Substring(0, currnetValue.Length - 1);
       56             }
       57         }
       58     }
    Regards
    Rado
  • 240
    There is a bug with the latest version.  You can set the .CurrentValue="" property during Pre-Render and that will clear the value for you.
