630
Customizing X Axis on a Column Chart
How can I remove the series names in the chart below. Because I am using a legend, I want to remove the series labels 'open' and 'closed'. I then would like to have the label item (a formatted date string ) appear below the columns. I am using the 2010.1 version of webchart
  • 630
    Verified Answer
    I figured it out-
    As the documentation states, in this case the X axis is a SetLabelAxis Object. However it took some figuring out to determine what that really meant. In the chart.Axis.X, there is a SeriesLabels and an itemFormat. By setting the itemFormat to None, the Open and Closed labels did not appear. Now I needed to set the formatting of the Series Label to look like the item format. Here is what I did:
    // X Axis setup
    myChart.Axis.X.Labels.Font = AxisFont;
    myChart.Axis.X.TickmarkStyle =
    AxisTickStyle
    .DataInterval;
    myChart.Axis.X.LineThickness =
    this
    .axisLineThickness;
    myChart.Axis.X.TickmarkInterval = XAxisTickMarkInterval;
    myChart.Axis.X.MajorGridLines.Visible =
    false
    myChart.Axis.X.MinorGridLines.Visible =
    false
    myChart.Axis.X.Labels.ItemFormat =
    AxisItemLabelFormat
    .None;
    myChart.Axis.X.Labels.SeriesLabels.Orientation =
    TextOrientation
    .Custom;
    myChart.Axis.X.Labels.SeriesLabels.OrientationAngle = 315;
    myChart.Axis.X.Labels.SeriesLabels.Flip =
    false
    myChart.Axis.X.Labels.SeriesLabels.VerticalAlign = System.Drawing.
    StringAlignment
    .Near;
    myChart.Axis.X.Labels.SeriesLabels.Font =
    new System.Drawing.Font("Verdana"
    , 10);
    myChart.Axis.X.Labels.SeriesLabels.FontColor = System.Drawing.
    Color
    .Black;
    myChart.Axis.X.Labels.SeriesLabels.Visible =
    true
