It is possible to databind component using WebHierarchicalDataSource object, and at the same time use a template for all dynamic item?
And use a usercontrol in the template? I have some usercontrol in the template, one inside the other. Creating item by code behind, the second usercontrol nevel does not render.
It's possible someone of this options?
Hi Asma,
I have a similar problem to Josep. I need to have html controls -check boxes, in the itemtemplate tag of the webexplorerbar.
I have succesfully displayed my dataset using codebehind, with the parent resultset as the menu items,and the child resultset as the subitems. How can i do this ?
The link you supplied has no html controls to illustrate usage of itemtemplates.
Hello Josep,
Would you like me to continue to find a solution for you since you are not using it, or is it something you may visit again?
-Asma.
The problem is to bind control using a Template to show items in html format, not as a list. On binding, the property "TemplateId" is missing.
But this page was a demo, and finally we don't need this control because the page is some different now in our project.
(Sorry, my english is bad)
Have you had any chance to create a sample.
Asma Developer Support EngineerInfragistics
https://ko.infragistics.com/support
You can bind WebExplorer Bar to a WebHierarchicalDataSource.
Regarding the issue with user control not rendering properly,can you please send me a sample of what exactly you are trying to do?
Asma.
