I am using UltraWebGrid v9.2. I don't set footer. No height. Add new row is not allowed. I manually added 3 rows and I see one empty extra row on the bottom.
Do I need to set something else to get rid of it?
Hello Al,
I would like to hear back from you. Please let me know if you still need further assistance with this request.
Thank you.
Sincerely,Mike D.Developer Support EngineerInfragisticswww.infragistics.com/support
Mike,
I set AllowAddNewDefault property using property window, but AddNewRow property has to be set in aspx code.
I don't not see that in property window in DefaultLayout section and that was a problem.
Thanks for your help.
Setting the AddNewRow in the Markup works as well. To set the AddNewRow Visible property using the property window, expand DisplayLayout. The AddNewRowDefault property is the third item under DisplayLayout. Expand the AddNewRowDefault node to set the Visible property.Please let me know if this helps.Sincerely,Mike D.Developer Support EngineerInfragisticswww.infragistics.com/support
