I have a number of WebDropDown controls on a page. To make them look sensible and resize with the page, the width of the control is set to a percentage of the containing table cell.
It would be nice to set the width of the dropdown block to be the same as the control itself (visually thats what you want most of the time). However setting DropDownContainerWidth="100%" results in the dropdown section becoming a FIXED width - with no bearing on the width of the control itself (I have several on this page of widly varying sizes, and the dropdown bit is identical for each when set as above).
This seems like a DIV somewhere in the control is being set to a fixed value, when it should vary according to the control width.
if this is a bug can you please tell me if its being fixed sometime. If its not, can you give me a workaround that dynamically sets the dropdowncontainerwidth properly?
A support case has been created for your request, it's indeed an issue that will be fixed. I will let you know when that's done.
Thank you !
Angel
