Hi All,
I really need some help here. I am a Infragistic newbie and am attempting to mimick the Ajax Toolkit TextBox autocomplete with the WebDropDown (WDD) control. I essentially need to display user names, and capture user_id upon selection, so I thought the WDD would be perfect.
The issue for me is that currently my db holds 170,000 records and it will grow. With the AJAX toolkit auto-complete extender I am able to retrieve records fairly quickly using a prefix, but I then lose the user_id.
I studied the sample at http://samples.infragistics.com/2010.1/WebFeatureBrowser/Default.aspx but there are so many client and server side properties, I don't find that sample helpful.
I also looked at http://community.infragistics.com/forums/t/25626.aspx?PageIndex=2 but I am just getting more confused since there are no complete samples
I would really like a complete sample project where records are retrieved from a SS db and bound to the WDD, and as one can types in the WDD, records are returned according to the prefix int the WDD text box. I like to use ObjectDataSources but can easily use a datatable or follow a sample
Thank you in advance for any help,
Frank
Hi Angel,
Thanks for your response.
I have adjusted the code in my application according to your provided project, and at first all seems well, but I have some unexpected behavior in both my app and in the sample I emailed to you..
If I start to type ‘An’, all is well.
If I backspace and type in ‘Bro’, all is well
If I again backspace, type in ‘Wil’, all is well
If I then either use my keyboard or mouse to highlight the current value and press the delete button on my keyboard to start afresh, no matter what I type, nothing is displayed in the WDD
I then changed my approach and used an object datasource with better results at first but eventually get Javascript error thrown. I don't see a way for me to attach my sample project so I emailed them to you directly.
Any suggestions? I don’t think this is unreasonable behavior to expect from a user
Sincerely,
PS - I am using a SS 2008 version of AdventureWorks, VS.NET 2008, and Infragisitics V 10.1.
You don't need to handle ItemsRequested on the client , and set the current value. The control does it for you. Also you don't need the Update Panel, since the filtering causes an AJAX request also by itself.
Everything you need to do is set EnableAutoFiltering=Server, then (depending on the number of records in your DB) , use either LoadOnDemand or Paging (EnableLoadOnDemand=true or EnablePaging=true), and set your page size , PageSize=1000 for example.
This should do it.
I am attaching a sample for you.
Please let me know if you still experience issues.
Angel
I have it working somewhat now by increasing the Autofiltertimeout, however upon dragging the scrollbar, thereby triggering a LoadOnDemand, moving curser back into text box and entering entirely new values throws a Javascrip error
'Error: 'get_items().getItem(...)' is null or not an object'
If I remove the javascript I added, then nothing appears in the WDD after using its scrollbar, no matter what I type. Pleas help.
head runat
="server">
head
body
="Server"
="True"
="Name"
="Contact_Id">
script type
="text/javascript">
itemsRequested(sender, args) {
sender.set_currentValue(sender.get_items().getItem(0).get_text(),
true
html
usp_Contact_Get_Contact_NamesTableAdapter TA = new usp_Contact_Get_Contact_NamesTableAdapter();
DataTable dt = new DataTable();
//CODEBEHIND
protected void Page_Load(object sender, EventArgs e)
if (!IsPostBack)
dt = TA.Contact_NamesCombined();
Session.Add(
"Names", dt);
WebDropDown1.Focus();
else
WebDropDown1.DataSource = (
Anybody?? I really need some help here please.
PS - I currently have the WDD inside an updatePanel
