I am looking in to this control, and am wondering if it is possible to use a splitter pane as a content holder to load other pages in.
Kind of like a master/child page relationship, without the actual master child pages..
So If I have a splitter that has a top and bottom pane, and two panes in the middle..
I cold put a WebDataMenu in the left panel and based on the click event of buttons in the WebDataMenu, load aspx pages in the right panel..
Possible? Ideas?
Hello Daryl,
I think it would be possible to use a WebSplitter in your scenario. The WebSplitter is just a visual element, you will have to work with the other controls the same way as if they are not within the splitter. And it is possible to load a different aspx page at the second pane, as a result of some action from the first pane. You would just have to set :
WebSplitter1.Panes[1].ContentUrl = "Default.aspx";
Hope this helps.
Lyuba Petrova
Developer Support Engineer
www.infragistics.com/support
