Background
Our web application was initially in .NET framework 1.1 and Infragistics 5.1 and then a migration was
done to .NET framework 3.0 and Infragistics 8.2. We have a few ultrawebgrids in the application.
Issue
Post migration, we have added a few more Infragistics ultrawebgrids. The issue is when the session’s
timed out, all the rows present in these grids are lost.
This is happening only for the newly added controls and not for the existing controls.
Pls. let us know if there is anything specific to be done or any pointer on this.
Thanks in advance..
Hello grakgem,
Thank you for posting in our community. I can recommend you to follow this links in order to understand better how to upgrade your controls.
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2010.3/CLR4.0/html/Web_Using_Version_Upgrade_Utility.html
Also this link will be helpful and provides information about how to deploy them on any server type:
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2010.3/CLR4.0/html/Web_Deployment_Overview.html
As I can see you are using old versions of our controls, so you will need to make sure that they are supported, follow this link for more details:
http://ko.infragistics.com/support/supported-environments.aspx#SupportedEnvironments
I hope this information and links are helpful and educational.
For any further questions do not hesitate to contact me.
Sincerely,
Georgi Sashev
Developer Support Engineer
Infragistics, Inc.
