How can I get the web slider value clientside / thru javascript?
solved. it should be slider.get_newValue();
I tried that and it didnt worked. Slider.get_value() gives back and error saying object doesn't support property/method.
Were you able to get WebSlider value based on the JavaScript code I have provided?
Please let me know if you have any further questions with this issue.
Bhadresh
You can get web slider value using get_value(); method of WebSlider. The following line of JavaScript code will achieve this:
var Slider = $find("WebSlider1"); var SliderVal = Slider.get_value();
Let me know if you need any further assistance with this matter.
Bhadresh,
