Hi All,
My issue is this:
I have an "Export to PDF" option that I have coded to accompany any UltraWebGrids in my website. This uses the "UltraWebGridDocumentExporter", and has been working great - when I click the button the PDF document is generated and displays the data from the UltraWebGrid.
However, this only appears to be working when I run the export on UltraWebGrids that have had data loaded into them using the traditional:
"uwgTest.DataSource = someData;
uwgTest.DataBind();"
In some instances I am using the EntitySpaces esDataSource to bind data to the UltraWebGrid. It appears in these instances that when I try and export the data in those UltraWebGrids, the PDF is empty.
The interesting thing about this issue is that when I am debugging the method that takes control of generating the exported PDF, I can see that the UltraWebGrid passed to the document exporter DOES contain data:
"// The UltraWebGrid "currentUWG" contains rows at this point, even when coming from an UltraWebGrid utilising the EntitySpaces datasource
uwgDocumentExporter.Export(currentUWG);"
Does anyone have any ideas what might be going wrong here?
Many thanks in advance,
AJ
