70
Problem with Manual Load on Demand
I have a WebHierarchicalDataGrid with N childgrids. I need to generate the childs on the runtime, each time the user expands a level.
I follow this example, and it works: http://help.infragistics.com/Help/NetAdvantage/ASPNET/2009.2/CLR3.5/html%5CWebHierarchicalDataGrid_Manual_Load_On_Demand.html
But... it does not work anymore if I use this property:
childGrid.AutoGenerateColumns = false;
BoundDataField col = new BoundDataField();
col.DataFieldName = "IdDesgloseOP";
col.Key = "IdDesgloseOPa";
childGrid.Columns.Add(col);
BoundDataField col2 = new BoundDataField();
col2.DataFieldName = "ConceptoDesglose";
col2.Key = "ConceptoDesglosea";
childGrid.Columns.Add(col2);
BoundDataField col3 = new BoundDataField();
col3.DataFieldName = "ImporteBase";
col3.Key = "ImporteBasea";
col3.Header.Text = "Importe base";
childGrid.Columns.Add(col3);
e.Row.RowIslands.Add(childGrid);
childGrid.DataSource = dt2;
childGrid.Band.DataMember = "PruebasSelectDetalle";
childGrid.DataBind();
If I put AutoGenerateColumns = false, the row simpli doesn't expand anymore... Any idea?
  • 33839
    Are you putting AutoGenerateColumns = false on the main grid view?  Could you attach your sample here?  Are you making sure to set IsEmptyParent on the parent row?
    regards,
    David Young
