I have a reference to jquery in my project. I use it to animate a Menú.
I discovered that the webdatagrid sorting fails when I have this reference! If I remove the reference, it just works. This is the error I am receiving, when I try to sort a column in my webdatagrid
Any Idea?
Thanks.
Hello jrbosh,
The grid has its own Client-Side API that should be used to achieve the needed functionality. When jQuery API is used on grid elements to change their behavior some of the basic functions can be executed incorrectly.
You can use our new jQuery and MVC product if you want to have better jQuery compatability - https://ko.infragistics.com/products/ignite-ui
