I was wondering if there was any functionality included in the web data grid that allows repeatable columns. I have a requirement where the user has asked that a grid with 4 columns, be displayed as 3 seperate grids side by side, each with the same set of columns (to save screen real estate). Ideally I would be able to specify somewhere on the grid that it should repeat its columns x times, after y rows. I can do this using 3 seperate grids, but it would be much cleaner if there was only 1 grid on the page. Please let me know if there is any way to achieve this.
Thanks.
Sorry, I was never able to find a way around this issue, we eneded up using three grids side by side.
I have the same requirement does anyone have a work around besides 3 different grids?
There is no such feature "out of the box".
If you would like to see it in future releases you can submit a feature request : http://devcenter.infragistics.com/Protected/RequestFeature.aspx
