I am building a website using asp.net 3.5
I have a webdatagrid with two template columns. One column contains a DropDownList control, the other contains a WebDatePicker. The dropdown is populated by using an SQLDataSource object so that I have a list of values .
The idea is that the WebDataGrid will be populated by database values, ie. the DropDownList will display the database value for a certain row when the Page is loaded, likewise the webdatepicker.
I am using another, seperate sqldatacourxce object to try and populate the webdatagrid, however, I cannot select the correct field in either the dropdownlist or the webdatepicker.
Do you have code to do this or to point me in the right direction?
many thanks
