Hi all,
I have a WebDataGrid with 2 dropdowns and a normal text input, as well as some read-only fields. I've deployed the project to our IIS box. Firefox and Chrome work perfectly, double-click to edit in IE doesn't work at all.
The site is in trusted sites, with zone security set to low. I've tried this in IE 6 and 8 on a couple of diferent machines with no luck.The grid displays perfectly in IE, except for the lack of editing.
Any idea what I've missed here?
James
Thanks for the sugestion. I managed to solve this last week, forgot to post here though! Compatability mode in IE was eneabled by default for local intranet sites, turning it off solved the problem.
thanks,
Hello James,
Would you give us a little bit more information? Which Infragistics version are you using? Some time ago there was an issue with entering edit mode that was related to the hidden columns. If you have some columns that are hidden, would you try to show them and check if this resolved the issue?
Lyuba
Developer Support Engineer
www.infragistics.com/support
