I have a WebDataGrid with 3 dropdown edit providers, which need to cascade off the value of the first one (the value, not the text). All three are databound to seperate SQL sources. I've had a good look around the forums and found nothing useful, has anyone got this working?
thanks,
James
Hello James, Were you able to get this working? Did you have any further questions regarding this?
Hello James, You just need to create a class file Item.cs and set getter and setter for the variables as given below.
public class Item{ public Item() { }
public int ID { get; set; } public string Fname { get; set; } public string Sname { get; set; }}
Thanks SGowdra,
Item doesn't seem to be defined anywhere (for each Item item in data), I'm no C programmer but I can't see anything obvious im missing.
Hello James, I have attached a sample demonstrating this. Please let me know if you have any questions.
