We are having some issues with UltraWebGrid. The code works fine on IE 6 and IE 7, but on IE 8 it is throwing some javascript error like "igtbl_StateChange.base.init is null or not an object". Even tried using the latest version 10.2, but did not solve the issue.
Any help, suggestions for the same?
Thanks for the feedback.
Hi Rado,
Thanks for all the help. I figured out the issue. It was because I was running the page on IE 8 Beta 2. I installed the latest version of IE 8 for Vista and everything works fine.
Thanks again.
Installed the same and tried. But still the issue is not resolved. I think i did not give all the steps to reproduce the issue. I am extremely sorry for that. Please find the steps below.
1. Only on IE 8, works on IE 7 and IE 6
2. Once the page is rendered, select one of the items in the dropdown. The error also appers, when the dropdown scroll is used.
Hi John,
You are correct I used VS 2010 but now I'm using VS 2008 and the issue is not raised. Do you have MS AJAX Extensions installed, if not you can download it form here :http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=ef2c1acc-051a-4fe6-ad72-f3bed8623b4
Thanks.
Looks like you have run it using visual studio 2010. Can you please check it on Visual studio 2008. I ran your pages in Visual studio 2008 and the problem persists.
Meanwhile i am installing visual studio 2010 exptress edition, to check if it works fine in that environment.
John
