745
UltraWebGridDocumentExporter is Not working
Hi to all....
i am using VS2005 with infragistics 2007 vol.3... My query is am using UltraWebGridDocumentExporter for Exporting grid to PDF File..But its giving Error like this..
Failed to map the path '/ig_grid.css'.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.InvalidOperationException: Failed to map the path '/ig_grid.css'.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[InvalidOperationException: Failed to map the path '/ig_grid.css'.]
   System.Web.Hosting.HostingEnvironment.MapPathActual(VirtualPath virtualPath, Boolean permitNull) +8853098
   System.Web.Hosting.HostingEnvironment.MapPathInternal(VirtualPath virtualPath) +42
   System.Web.VirtualPath.MapPathInternal() +4
   System.Web.HttpRequest.MapPath(VirtualPath virtualPath, VirtualPath baseVirtualDir, Boolean allowCrossAppMapping) +107
   System.Web.UI.Page.MapPath(String virtualPath) +48
   Infragistics.WebUI.UltraWebGrid.DocumentExport.UltraWebGridDocumentExporter.LoadStyleFile(String cssStyleSheetName) +136
   Infragistics.WebUI.UltraWebGrid.DocumentExport.UltraWebGridDocumentExporter.GetCss(List`1 stylesheets) +174
   Infragistics.WebUI.UltraWebGrid.DocumentExport.UltraWebGridDocumentExporter.RenderDocument() +340
   Infragistics.WebUI.UltraWebGrid.DocumentExport.UltraWebGridDocumentExporter.PagePreRender(Object sender, EventArgs e) +477
   System.EventHandler.Invoke(Object sender, EventArgs e) +0
   System.Web.UI.Control.OnPreRender(EventArgs e) +8682950
   System.Web.UI.Control.PreRenderRecursiveInternal() +80
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +842
Version Information: Microsoft .NET Framework Version:2.0.50727.3603; ASP.NET Version:2.0.50727.3614
