Hi there!
I bind an ObjectDataSource to a UltraWebGrid according to your example of the online docu (http://help.infragistics.com/NetAdvantage/ASPNET/2010.2/CLR4.0/). The problem is that somehow all the properties of the generic list which are bound to the grid are set back to null resp. 0?!? Help needed! Thank you!
Regards,Dan
Hello Dan,
I am just checking about the progress of this issue.
Let me know if you need any further assistance.
I used the online documentation example in order to reproduce the issue :
http://help.infragistics.com/NetAdvantage/ASPNET/2010.2?page=WebGrid_Binding_WebGrid_to_ObjectDataSource.html
I used the Infragistics4.WebUI.UltraWebGrid.v10.2 Assembly as you have mentioned in your description:
http://help.infragistics.com/NetAdvantage/ASPNET/2010.2?page=Infragistics4.WebUI.UltraWebGrid.v10.2.html
I run the sample and the UltraWebGrid was loaded as expected, after update the grid values were changed accordingly the UpdateMethod of the ObjectDataSource.
Can you please provide more details regarding the circumstances : when the properties are set back to null resp. 0?
A Small zipped sample reproducing the issue will be appreciated.
Hope hearing from you soon
